Re: Re: Farmall H steering loose - will it matter with wide front?
Posted by Steven@nd on April 21, 2002 at 15:21:09 from (12.15.56.169):
In Reply to: Re: Farmall H steering loose - will it matter with wide front? posted by Only if you want to be able to actually steer on April 21, 2002 at 11:16:26:
Thank you for the sarcasm, I'm sure everyone enjoyed it.
As a matter of fact, we have a couple tractors we use everyday with loose steering and it doesn't matter at all because it doesn't shimmy on the road. The reason I asked the question is because I KNOW that H's and M's with narrow fronts will shimmy if there are loose parts in the steering system. I was wondering if they would do the same with a wide front.
Steven
Post A Followup
: Re: Re: Re: Farmall H steering loose - will it matter with wide front?
