Farmall Tractors Discussion Board
Farmall A Cooling
Posted by Ray on August 08, 1999 at 07:15:21 from (204.0.160.214):
I was just wanting to know if putting a water pump on my A would help in the cooling of the motor.
One other thing,after you run the tractor for about 30 minutes or so,the oil preasure drops to 0-2psi. Didn't know if putting a water pump on it would help keep the block cooler and in return keep the oil at a lower temp.
I know it's time for a overhaul but just can't afford it right now. Thanks for your help.
Post a Followup
: Re: Farmall A Cooling
