Re: Shifter kit info for IH tractors... 06, 56, 66, 86, 88 series
Posted by the tractor vet on April 26, 2002 at 19:12:34 from (216.196.13.49):
In Reply to: Shifter kit info for IH tractors... 06, 56, 66, 86, 88 series posted by Steven@nd on April 26, 2002 at 15:59:25:
It does not take much to fix them and do it wright and i do not need to buy somebodys make shift stuff , most shifting problems start from the clutch and dump valve getting out of adjustment and then people start jerking and tugging on the shifter and the rest is history. If everything is set the way it is suppose to be they shift real easy and with a littel work you can fix all the slop in the shifters it just takes a studying the systems and find the ware point , just replacing the headed pins can make a large differance.
Post A Followup
: Re: Re: Shifter kit info for IH tractors... 06, 56, 66, 86, 88 series
