560 killed new hydrualic pump HELP
Posted by ITFormulaGuY on March 26, 2009 at 17:14:02 from (69.89.181.138):
Summary: New pump, fluid, O rings, Gaskets, inspected everything, reasemble, everything work for a short time and now nothing.
well i just got done going through the hydra-touch system with Tele-a-depth. i took everything apart, ran it through the parts washer blew all the passages out with air. i double and trippled checked the orface that has a screen (size 31) as well as the piston to make sure it wasnt stuck. i did all of this since i changed the pump, fluid and filter..the org pump went out and the fast hitch wanted to float where ever it wanted to when it was working. There were some times it was still under high preasure with the new pump so i moved the levers to run the fast hitch up and down and to get the air out of the lines, at one point it was pulling the tractor down so hard it would make the tractor stumble and shut the tractor off. Made more adjustments and put everything back together. Hooked to the field culitivator and it lifted it no problem. drive to the field let it down and everything is working great!! come to the end of the field and go to raise the tool and NOTHING... NOTHING but one hot headed guy that was ready to throw a match at it..!!! GRRR is there anything i missed? i've been using IH's online parts cataloge which is a great help. any input would be great..
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
