Re: Changing oil on a Super M
Posted by Andy Martin on May 13, 2002 at 12:40:03 from (12.74.161.167):
In Reply to: Changing oil on a Super M posted by Tim Malin on May 13, 2002 at 12:27:47:
Just take out the drain plug. The oil will come out by itsself unless it is very dirty. If none comes out, poke a stick or heavy wire in the hole to break the crud loose so the oil will drain. There is a drain plug on the oil filter but I never use it. The oil drains out if the oil filter nicely unless it is so dirty it is all plugged up. Use a narrow sharpened tool to get the oil filter gasket out if it is hardened and stuck in the groove (a normal condition if the oil has not been changed in some time). Don't gouge the casting. If you don't have a new gasket (it should come with the filter) the old one may work if you do not disturb it. Change the air cleaner oil at the same time. Clean the cup good, but no other cleaning of the air cleaner is necessary. This is also a good time to give the water pump two shots of grease in each zerk and oil the cups on the starter and generator if they have them. Don't do the water pump more than two times per year. Also oil the distributor/magneto drive if there is an oil cup and pull the 1/8 slot pipe plug and screw in a zerk to give the mag/dist a shot of grease. Again twice per year max. And two shot of grease in the pilot bearing.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
