Rust in tank - Farmall H with baffles...
Posted by Steven@nd on May 19, 2002 at 07:59:41 from (12.15.56.108):
My H runs good, other than I think something is plugged in the carb since it doesn't matter where I put the high speed jet, it runs the same. I will fix that when I take the gas tank off because my big problem is that I can only run about 5 minutes before a piece of rust plugs the inlet to the sediment bowl. My tank has the baffle in the middle of it.
What has worked for you guys for the baffled tanks? I thought I would take it off and have them try steam cleaning it in town (free because I do business there). Does that sealer goo work in a tank with a baffle? I assume it would take more because some would stick on the baffle too.
Thanks for the help!
Steven
Post A Followup
: Re: Rust in tank - Farmall H with baffles...
