Re: SMTA Oil Pressure
Posted by Theman on May 22, 2002 at 07:54:10 from (12.19.86.5):
In Reply to: SMTA Oil Pressure posted by GooseCreek on May 22, 2002 at 07:11:11:
IH engines in good shape (overhaul) typically seem to run high oil pressure. It is probably lifting the pressure relief valve in the oil pump which is OK. The best way to really know what pressure the system is under is to use a good calibrated gage on it.
The problem of dieseling is not related to oil pressure at all - other than the fact that there is no oil pressure present when the engine - thus the oil pump is running backward. There are some very hot surfaces in the combustion chamber that cause the fuel to ignite even without an arc at the spark plug. If you have oil coming out of the air inlet when it diesels, it is, in fact, running backwards. That oil is coming from the oil cleaner cup. Be sure to check that the oil level is up to the mark in the cup if the engine has blown some out.
Some things to do to relieve the dieseling problem are to let the engine idle for several minutes to "cool down" before shutting it off or turning off the fuel and let the carb run out of gas. If you do the latter, be sure to turn the ignition switch off before leaving the tractor.
Post A Followup
: Re: Re: SMTA Oil Pressure
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
