Re: Black Smoke and Knocking
Posted by John on June 05, 2002 at 18:30:02 from (24.80.56.242):
In Reply to: Black Smoke and Knocking posted by Jeff on June 05, 2002 at 17:37:45:
The black smoke is unburned fuel. An engine develops it's highest vacuum at idle and it is probably loading up fuel in the system and when you throttle up it gets shoved out. Maybe lean it out a bit.Air cleaner clean?
The knock should not be there. Did you plasti-guage the rod bearings? If it gets louder you might be wise to pop the oil pan and take the rod bearing caps off and have a look. Mains too if you did them. Wrist pins in oval holes in the pistons can also cause the knock.
I built a W4 engine and when I put the rod bearings in the top of the rod was not centered on the wrist pin in the piston and it caused the wrist pin bushing to bind and to be very tight. Would not work itself out I had to open it up and take off the rod caps and release it by centering the rod on the pin.Do you remember any/all rod being stiff when you installed them? Good luck, hope I didn't scare you. J
Post A Followup
: Re: Re: Black Smoke and Knocking
