Re: Re: M with PTO problems
Posted by Jerry S on June 18, 2002 at 07:01:50 from (63.71.59.98):
In Reply to: Re: M with PTO problems posted by Bob in SE Nebraska on June 17, 2002 at 16:38:25:
Thanks Bob. I wasn't sure there was some kind of pin or clip that holds the shaft in there or if it just slipped in. Sounds like I will just have to change the seal and see how that works. I am guessing the case IH dealer is the place to get the seal?
Post A Followup
: Re: Re: Re: M with PTO problems
