Re: different bolt patterns for hyd. pump for 300 utility H motor
Posted by Steven@nd on June 18, 2002 at 19:53:11 from (12.15.56.181):
In Reply to: different bolt patterns for hyd. pump for 300 utility H motor posted by mark on June 18, 2002 at 14:54:13:
The Super H, 300, and 350 with live hydralic pumps came with a different front cover and heavier timing gears. You can put the live pump on your H by modifying the holes or changing the front cover. You can get by fine with the stock cam gear, although it won't take a whole lot of abuse, normal use it will last a long time.
Steven
Post A Followup
: Re: Re: different bolt patterns for hyd. pump for 300 utility H motor
