Re: Magneto impulse help, please!
Posted by Farmer Gene (WI) on July 21, 2002 at 14:02:50 from (64.91.86.43):
In Reply to: Magneto impulse help, please! posted by Mike Schotte on July 20, 2002 at 06:14:59:
Mike, are you sure you are turning the mag in the right direction? also you might have to hold the mag in the same position as it fits on the tractor as it seems that the pawls work by gravity. If you turn it in the correct direction the spring should wind up then it will snap as the pawls let it go. In any case the rotor should turn unless you have a bad gear inside.
Post A Followup
: Re: Re: Magneto impulse help, please!
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
