to Scotty(NY)
Posted by richard on July 23, 2002 at 06:00:30 from (199.131.159.125):
Scotty, I'll check each whel and turn them and listen for bad bearingsfor that noisy A rear-end.
If I have to replace the differential or drive shaft bearings you seemed to indicate that I don't need to split the tractor. Is that right?
Also, could I remove the shifter/transmission cover and look inside and try to lift the shafts and see if they jiggle or are worn and loose too?
Oh how I would like to fix those bearings but I don't have a hoist or know anyone who has one.
Thanks I hope you see this and can reply. Richard
Post A Followup
: Re: to Scotty(NY)
