Re: to Scotty(NY)
Posted by ScottyNY - a little long again on July 23, 2002 at 06:50:22 from (128.59.123.240):
In Reply to: to Scotty(NY) posted by richard on July 23, 2002 at 06:00:30:
You're pretty much on the money. Richard. The differential and axle bearings are done from the sides, so no split. Two average healthy people can handle it without a hoist, but I'll caution again that you must be careful and block things up well on a level surface. While doing one side leave the wheel and tire on the other to help balance and ballast things -- jack the other side only high enough to get the whell and rim off, then let the jack back down to level. BLOCK under the center jack pad on the bottom of the tranny. You may be lucky and find that it is only the lower axle bearings. On my tractor, these were the ones in worst shape and are fairly easy to do. You don't even need to separate the axle or final housing from the transmission. Just drop the pan, loosen the outer bearing retainer, remove the inner bearing cover. One nut off and the axle will drive out from the inside, dropping the bull gear. The only seals are the oil seal and felt washer on the bearing retainer. Everything else is gaskets. A parts manual gives a good picture of how it all goes together. If you should have to do the top bearings, I would suggest you pull the axle and bull gear first anyway. This gives you the flat bottom, and removes the possibility of crushing your pan if you should put it down hard (or even gently if its rusted thin). Neither the I&T or the IH Service manual for the A's goes into the fine details, but they are both worth having for the order of taking things apart. I'd get one or both of them as well as th parts book before baling into the project.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
