Re: Re: Re: Re: 12 volt Alternator
Posted by KX on August 12, 2002 at 13:19:34 from (66.129.8.2):
In Reply to: Re: Re: Re: 12 volt Alternator posted by Doug in OR on August 12, 2002 at 12:32:39:
Are we talking "better" or spinning the alt shaft faster with lower rpm from the engine? If the latter, a bigger pully on the alt and is what you want. How do you define better?
Post A Followup
: Re: Re: Re: Re: Re: 12 volt Alternator
