Re: Re: Missing H
Posted by Ben Huyge on September 03, 2002 at 10:33:53 from (65.93.120.188):
In Reply to: Re: Missing H posted by Charlie on September 02, 2002 at 18:31:15:
Charlie,
Thanks for getting back to me, and thanks to everyone else who responded. I should have clarified that it is a distrubtor ignition system on the particular H.
Charlie, the choke makes no difference, I played around with it to see if that was a problem, but there was nothing.
The only thing that I did not consider was the possibility for a ballast resistor. I did change the tractor to 12 volt and I purchased a new 12 volt coil, as the old 6 volt gave up the ghost. So I went a purchased one from my local CaseIH dealer. I asked on three seperate occasions whether or not I required a ballast resistor for this particular coil and they said no. So, I went with that. However, maybe I should get one.
Perhaps I should get one to see if that will make the difference. As far a startin goes, the thing sparks right up, so I know the points are in good shape. The plugs and wires are all new, in fact I even exchanged the new plug wires with the ones on the 130 and there was no difference in performance.
I watch the valves, and they all seem to opening and closing the way they should.
However, I will look into all of these matters and hopefully I can figure out the problem.
Thanks again,
Ben
Post A Followup
: Re: Re: Re: Missing H
