Re: Re: 1944 A Coolant System Flush
Posted by John Martin on September 15, 2002 at 14:02:46 from (207.172.11.150):
In Reply to: Re: 1944 A Coolant System Flush posted by LanceM on September 15, 2002 at 12:34:31:
Thanks for the reply. Does thermosiphon imply there is no water pump? I haven't been into the cooling system at all, so I really don't know how it's built...just got the tractor this summer from inside the family. Engine seems to run very hot, and I've been having distributor problems, so the timing hasn't been set quite right yet...I know that the wrong timing can cause the engine to run hot. Is there a way to install a temperature gauge on the 44 A? It would be helpful for troubleshooting. Thanks again for your input.
Post A Followup
: Re: Re: Re: 1944 A Coolant System Flush
