Re: Hydraulic Pressure
Posted by Scott Swanson on October 17, 2002 at 09:54:42 from (209.180.31.9):
In Reply to: Hydraulic Pressure posted by Layle Willis on October 17, 2002 at 09:40:56:
I always thought Super H's had live hydraulics. Does yours have a belly pump? If so, It may be the regular belly pump for H. The low pressure ones punched about 500 pounds. The improved ones(with yellow figure "8" painted on them) punched around 800. Look at your magneto or distributor. If there is a "pump" looking thing between it and the engine, you have "live hydraulics". Then I would advise you to jump up and down. You are indeed...blessed!
Post A Followup
: Re: Re: Hydraulic Pressure
