Re: 560 Farmall - hydraulics
Posted by Wheels on October 18, 2002 at 21:15:32 from (205.243.25.146):
In Reply to: 560 Farmall - hydraulics posted by Matt Clark on October 18, 2002 at 07:08:03:
I agree with RPM, the problem is most likely in the cylinder. You may be able to check that by disconnecting the hydralics with the bucket tilted up and if it still settles your problem is in the cylinder. If not you will need to put a block under the bucket so you don't loose a bunch of oil reconnecting the hoses. They will be under pressure, be careful. You should not be able to kick the knobs out of place. There should have been a rollpin in them to hold them in place at either double or single. Take the cover off, and if you remove the two (I think) bolts that hold the plate that the knob comes out of, you can take it off and it should come apart. The rollpin goes in the shaft just outside of the plate and in a little tin piece that limits how far you can turn. Putting the assembly back together on the tractor can be fun. You can determine which one is for which control by wiggling the lever and following the linkages. Good luck Wheels
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
