Farmall Tractors Discussion Board
Re: Electronic Ignition/The Red
Posted by RED Blooded on August 25, 1999 at 18:01:45 from (206.74.34.166):
In Reply to: Electronic Ignition/The Red posted by ltf in nc on August 24, 1999 at 12:45:05:
Not being familiar with the type of ignition systems that replace a regular points/condensor type system I have one question,if you still use the points to break the gap whats the difference in using the condensor that is already there.I understand how it could be done and agree that it is a cheap alternative,but why do it?I cant remember the name of the company that makes it,but it replaces everything,points,condensor and all.No moving parts to wear out!
Post a Followup
: Re: Re: Electronic Ignition/The Red
