Farmall H Charging Trouble
Posted by Tony North Carolina on November 10, 2002 at 18:04:05 from (205.188.209.78):
I have a 41 farmall H trouble that i cant figure out. When running The tractor it shows a slight charge and keeps the battery up. But if i run it at night with the lights on it shows a big discharge and kills the battery. Tractor has a magneto on it so the lights will work without the battery but get dim when battery goes down. I have had the generator checked and put 3 voltage regulaters on it in the past 4 years and still the same thing. Tractor is still 6 volt. When i bought the tractor it did not have a voltage regulater on it, it had something else, a relay or something and everything worked great, tractor charged night and day but when it went out i was told you could not get them anymore and to put the voltage regulater on it. Well, it has not worked right sence.
Post A Followup
: Re: Farmall H Charging Trouble
