Re: Super A Farmall update
Posted by Dave_Id on November 10, 2002 at 19:45:01 from (67.250.152.174):
In Reply to: Super A Farmall update posted by kevin on November 10, 2002 at 19:12:21:
The place that these 113 engines normally crack is right behind the carburator... water jacket right there... hopefully if you have a crack, it doesn't go to the top of the block where the head gasket though... you'd have a real mess then..Good luck on the restoration,.. the A and Super A's are fun little tractors for restoration.
Post A Followup
: Re: Re: Super A Farmall update
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
