Re: 504 vrs 544?
Posted by wayne in PA on November 30, 2002 at 06:58:51 from (67.208.1.225):
In Reply to: 504 vrs 544? posted by JR on November 29, 2002 at 14:43:09:
I have a Farmall 504 (there are some differences between Farmall 504's and International 504's), and according to my research it does not have cylinder sleeves. Seems like most other Farmal/International gas engings have cylinder sleeves. This is important in rebuilding the engine, as the sleeves will allow you to rebuild to original spec's without changing the balance dynamics. And it should be lower cost, since you can do more of the work in your own shop.
Unless your 544 is another one of those that does not have cylinder sleeves, I think you'd be better off rebuilding your original engine.
Good luck
WW
Post A Followup
: Re: Re: 504 vrs 544?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
