Posted by slydog on March 28, 2009 at 16:18:38 from (75.104.25.115):
I had a leak on my water pump so I tightened the packing nut and it stopped. I thought I had the problem fixed. I just ran it today and after I shut it off it leaks bad out the front of the fan. The fan even feels loose (you can wiggle it back and forth). Do I try and tighten it up again or is there something else wrong? If I have to take the water pump off do I have to remove the radiator to do it?
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
