Re: Farmall H water pump leaking
Posted by Wil Sick on March 28, 2009 at 17:18:53 from (69.66.140.43):
In Reply to: Farmall H water pump leaking posted by slydog on March 28, 2009 at 16:18:38:
You probably have a bearing out in the water pump. Yes,I take off the radiator to work on the water pump.
