Re: Re: Re: Super A electronic ignition
Posted by Ken T. on December 31, 2002 at 12:43:55 from (192.136.16.3):
In Reply to: Re: Re: Super A electronic ignition posted by patpeery on December 31, 2002 at 11:40:50:
Setting the timing is pretty simple, actually. You will need a timing light. Timing lights are available in two main varieties. One type operates off the tractor battery. The other type plugs into 110 volt AC. Either one will work. You connect the timing light to the #1 spark plug wire (closest spark plug to the front of the tractor). Then you loosen the distributor hold-down clamp. You then need to obtain the timing specs for your tractor from a maintenance manual. Those specs will tell you how many degrees before top dead center (BTDC) the timing is supposed to be set at and at what engine RPM the motor is supposed to be running when the timing is set to those specs. It is now best to find your timing mark and pointer. I don't know where they are on a Super A. They might be on the pulley at the front of the crankshaft, or they may be on the engine flywheel. The maintenance manual will tell you where they are. Once you find the timing marks and pointer, highlight them with a piece of white chalk so they will be easier to see when observing them with the timing light. Now you start up the tractor and set it to the prescribed engine RPM and aim the timing light at the timing marks and pointer. While observing the timing marks with the timing light, you can rotate the distributor by hand slightly one way or the other until the timing marks read the value that is given in the specifications. When the timing marks indicate the correct value, re-tighten the distributor hold-down clamp and shut the tractor off. Disconnect the timing light and you are finished. This might sound kind of complicated, but it is really quite simple. It is recommended that you read the ignition timing procedure in the maintenance manual for your particular tractor before you set the timing because it may say that you need to disconnect a vacuum advance line or something like that before setting the timing.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
