Re: Farmall H live hydraulics saga continues...
Posted by Bob M on January 10, 2003 at 08:43:21 from (165.170.128.68):
In Reply to: Farmall H live hydraulics saga continues... posted by Steven@nd on January 09, 2003 at 16:27:53:
A few comments from a mechanical engineer's perspective (which incidentally I happen to be...) 1 - Driving the pump thru a simple universal joint operating at an angle can work. But has a problem: Due to the single joint setup, the pump will undergo a significant sinusiodal variation in output shaft RPM twice each shaft revolution. The sharper the angle, the greater the variation. (Anyone who has turned a corner pulling a PTO-driven bush hog has experienced this...)
Anyway assuming a joint angle of 20 degrees (eyeball estimate), and limiting the angular acceleration to a "reasonable" level (<1,000 radian/sec**2 for you engineers) a quick calculation says the pump shaft should not exceed about 850 RPM. And even at this level there will be significant radial (side) stress on both the U-joint and the pump input shaft bearing. So as soon as you get ANY wear in either the U-joint or pump bearing, it will become rapidly VERY noisey and be well on it's way to self-destruction. 2 - You could drive the pump through some sort of CV joint to eliminate the sinusoidal speed variation from the cross-joint universal. However the matter of radial load on both the CV joint and the pump bearings will remain. Also unless a high quality and fully sealed CV joint is utilized (translation: expen$ive!), the joint will suffer from a short life.
3 - A better plan from a cost/life perspective is to belt the pump to the crankshaft via a timing belt or synchronous (Polychain, etc) drive. Synchronous belt drives are cheap, require no lubrication, are reasonably tolerant of dirt, and will handle huge amounts of power (e.g. Harley -Davidson final drives).
To the issue of the radial load imposed on the front crank bearing from a synchronous belt-driven pump, the load will be only modestly higher than the radial load imposed by the timing gears onto the crank by an OEM live (distributor) pump. Also if you look at the combustion and dynamic loads already carried by the crank mains, the additional load imposed by a synchronous belt drive pump will be inconsequential. My 2 cents! ...Bob M
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
