Farmall Tractors Discussion Board
Re: Re: Another Touch Cortrol Question On '50 Super A
Posted by Merlin on September 01, 1999 at 19:04:59 from (208.231.102.143):
In Reply to: Re: Another Touch Cortrol Question On '50 Super A posted by Daniel on September 01, 1999 at 18:09:29:
Thanks Daniel. No, its not leaking or making any kind of noise. If I rev the motor all the way up, it lifts about 2 inches or so. I took the cone shaped filter off the side and it looked fine. Its full of fluid. When I bled it, fluid would come out of the fill hole when the levers were to the rear position. Putting both levers forward, the fluid would go back down. I keep it well greased and the rockshaft is loaded with every day grease, but no leaks that I can see. I guess now is the time to make a yard orniment out of it.
Post a Followup
: Re: Re: Re: Another Touch Cortrol Question On '50 Super A
