Injector nozzles on 560 D Head
Posted by RO on January 20, 2003 at 18:51:33 from (24.124.18.154):
Should antiseize compound be used on the nozzle bodies holding the injectors before they are installed, to prevent corrosion between the nozzle body and the head? The top seals ought to prevent moisture from entering, but there still seems to be some minor rusting. The two bolts holding each nozzle body will get antiseize for sure.
Also, the glow plugs all show the same resistance, which I'm assuming means they are all good---I know some of them are, but haven't yet put the 12 v. to them.
Thanks for your experience.
Post A Followup
: Re: Injector nozzles on 560 D Head
