Farmall F-20 oil pump
Posted by Ben Haag on January 23, 2003 at 17:45:24 from (63.166.167.60):
i just recently put new rings in farmall f-20. i never took the oil pump off, just the oil pan. do i need to prime the oil pump?? if so how?..I also have one connecting rod bearing that is to tight. IS there a certain direction that the bearings go inside the cap?? i dropped on out on the carpet below and just stuck it back in. I havent got the oil pan on yet so.... ALso are the shims the exact same size on both sides of the caps? answer what ever you can. it will be greatly appreciated!
Post A Followup
: Re: Farmall F-20 oil pump
