Re: Rebuilding an engine
Posted by Steve - IN on January 31, 2003 at 15:51:32 from (12.222.17.160):
In Reply to: Rebuilding an engine posted by Tim Malin on January 31, 2003 at 15:40:42:
Tim,
I've built a lot of the 1.6 Fords. The 2.0 is the same block with an OHC head. If yours is a pushrod - chances are it's a 1.6 or ~100 cu in. Once you've removed the head, you should be able to lift it and turn it anyway you want - which you'll need to do anyway when you're rebuilding it.
Steve
Post A Followup
: Re: Re: Rebuilding an engine
