Getting ready to change the oil on my 'H'
Posted by Gary The Rookie Farmer on February 12, 2003 at 08:59:10 from (66.188.30.8):
First off how do I tell if the current oil is detergent or non-detergent? FWIW- I read somewhere that it is a bad idea to switch to detergent oil if non-detergent oil was being used.
Where do I find an oil filter for my 'H'?
Any other tricks I need to know about?
Post A Followup
: Re: Getting ready to change the oil on my 'H'
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
