Re: Farmall M won't turn over.
Posted by Bill L Md on March 15, 2003 at 15:00:36 from (68.55.41.86):
In Reply to: Farmall M won't turn over. posted by Farmall Daddy on March 15, 2003 at 13:56:32:
Did you check to see if it will turn over by hand.If the wiring is screwed up and as long as the battery is hooked up correctly it should turn over.It sounds to me that there is more screwed up then just some wires.Take the plugs out and see if you can turn it with the crank or bump it around with the starter,put somthing down the cyl.too lubricate the pistons and sleve walls.
Post A Followup
: Re: Re: Farmall M won't turn over.
