Need help removing crank pulley on A
Posted by Chad on March 27, 2003 at 05:45:33 from (152.72.252.244):
Hi I am replacing the front crank seal on our 1940 A. It leaks terrible. I have the correct puller for the crank pulley so I pull from behind so I do not break it. I pulled the set screw and jam nut 180 degrees from the key. But I put the puller on it and it will not move it wants to bend the 1/2" bolt that is used in the puller. Should I add heat? Or just let it sit with pressure on it? Any Ideas?
Chad Penny
Post A Followup
: Re: Need help removing crank pulley on A
