Re: Super C leaking fluid at hydraulic pump.
Posted by Hugh MacKay, CNKS, gene b, others on March 29, 2003 at 15:40:53 from (64.228.11.131):
In Reply to: Super C leaking fluid at hydraulic pump. posted by John on March 29, 2003 at 09:48:17:
John: Is your leak entirely external? Is there a possibility hydraulic oil is also going to crankcase? I have owned 6 tractors with this setup, knock on wood, have never had problems. I currently still have three of them, so want to stay abrest of how to fix. These also have a history of leaking along pump shaft, past timng gears and into crankcase. I see gene CNKS and others discussing a sleeve for pump shaft as well as seal. I will watch for advice you recieve.
Post A Followup
: Re: Re: Super C leaking fluid at hydraulic pump.
