Re: Wondering what this part was used for on Fast Hitch as seen in old Farmall 350 brochure
Posted by Heath on April 13, 2003 at 10:38:02 from (208.29.50.254):
In Reply to: Wondering what this part was used for on Fast Hitch as seen in old Farmall 350 brochure posted by Ray in Pa. on April 13, 2003 at 09:44:31:
It is a depth control rod. It has a series of notches that that go through a hole in the top cylinder pin with a spring loaded latch in it. I believe you turn the rod 1/2 turn and pull it up or down to the setting you want and then turn it 1/2 turn back and when you move the fast hitch up or down it hits the special plate on top of the cylinder which hits the little button in the cylinder stopping it. It is usefull for lowering the fast hitch to the same exact depth every time.
Post A Followup
: Re: Re: Wondering what this part was used for on Fast Hitch as seen in old Farmall 350 brochure
