Farmall Tractors Discussion Board
Re: Ultimate Tractor/Cutter rig
Posted by I'm confused on September 13, 1999 at 13:39:07 from (165.117.55.23):
In Reply to: Ultimate Tractor/Cutter rig posted by Harold H on September 11, 1999 at 14:19:56:
Was this machine pushing a bush hog backwards? My experience, which is limited, has shown that bushhogs & finishing mowers cut much better in the forward direction. Also, with the single front (aka rear) wheel, I believe I'd stay on level ground!
The biggest, baddest cutting machine I've ever seen is one of the NH 8810's with the 7', 4 bladed bushhogs that Georgia Power uses to clear power lines. 4wd, Duals front & back, etc. Whatever you can get under it, it will cut!
Post a Followup
: Re: Re: Ultimate Tractor/Cutter rig
