Re: Re: Re: Re: Re: Re: Re: Re: Hugh MacKay and th
Posted by RN on June 14, 2003 at 20:09:56 from (166.126.218.251):
In Reply to: Re: Re: Re: Re: Re: Re: Re: Hugh MacKay and the U. posted by Diana on June 14, 2003 at 19:52:34:
350D starting drill now: fuel on, key on, use manifold heater- slow count 60, then engage starter. Should fire 5-ten seconds. If doesn't start repeat drill 2 more times. Still no start? something is off or weather cold. Our 350D has water block heat for winter starts. Fuel pump serviced over winter, weak/worn cylinders fixed, started good last month for playing in the dirt- 3 bottom plow in garden, disk small corn field. RN
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Re: Hugh MacKay and th
