706D has a Problem
Posted by cagle on June 21, 2003 at 17:03:46 from (209.206.206.86):
My 706D has a problem. If you hit the brake to turn shorter, tractor will stop. It also hesitates when you let out on the clutch. When it stops with the brake, if you rev up the engine it will eventually take hold, but with a jerky motion. It has a TA, and is out on low side. I have a new MCV pump, and have rebuilt the MCV. It was doing this prior the pump and MCV change. What else can it be? Filter has also been changed..
Post A Followup
: Re: 706D has a Problem
