Re: 706D has a Problem
Posted by REDMAN on June 22, 2003 at 09:01:47 from (206.10.109.62):
In Reply to: 706D has a Problem posted by cagle on June 21, 2003 at 17:03:46:
DID YOU CHECK THE OTHER PUMP?IT IS ON THE SAME SIDE AS THE MCV RIGHT IN FRONT OF THE AXEL.THAT ONE WILL GO MOST TIMES BEFORE THE MCV PUMP DOES.IT ALSO FEEDS THE MCV PUMP SO IF IT IS OUT AND YOU HIT THE BRAKES IT WILL STARVE THE REST OF THE SYSTEM
Post A Followup
: Re: Re: 706D has a Problem
