Re: SMTA Hydraulic help needed.....
Posted by Dan on July 08, 2003 at 21:46:49 from (12.144.250.243):
In Reply to: SMTA Hydraulic help needed..... posted by Terry on July 08, 2003 at 08:58:59:
I have a SMTA with the remote valve also but no power steering. From your pictures it looks like your pressure line goes from the pump, through the priority valve then into the left side of teh lift all box. on my SMTA the pressure line goes into the right side of the lift all box. You have to have the handle locked back on the lift all valve to work the remote or the otherway around if using the lift all. It seems like your pressure line is hooked into an outlet of the lift all. You might try running the pressure hose to the top fitting on the right and see if it helps.
Post A Followup
: Re: Re: SMTA Hydraulic help needed.....
