Re: antifreeze in the oil
Posted by mike in mn on July 09, 2003 at 15:59:20 from (66.228.233.209):
In Reply to: antifreeze in the oil posted by dave w on July 08, 2003 at 18:50:17:
I would have the head checked for cracks. If it has any have them fixed.also check your head gasket for blow outs. something else that you might want to have checked are your sleeves. One of them might have a crack or two in it. But you cant see them. the sleeves will have to be sandblasted on the back side then looked at through a magnafying glass to see the cracks. the early case tractors are known for cracking the sleeves. and I only know of a couple oliver tractors doing this.
Post A Followup
: Re: Re: antifreeze in the oil
