Re: H fanbelt needs to be tightened?
Posted by terry on July 13, 2003 at 19:33:51 from (67.250.216.186):
In Reply to: H fanbelt needs to be tightened? posted by John on July 13, 2003 at 19:20:22:
Hi, I will try and explain this.
You are correct, you need to loosen the set screw.
It needs to be loosened enough to allow the collar to turn, might just be easier to take it completely out.
Usually there are two points on the front half of the pulley where you can take a long blunt end punch and turn this half of the pulley clockwise to tighten the belt. One of the areas where you can use the punch is where the set screw is. Clockwise is determined by standing in front of the tractor.
If the area is covered with 50 years of crud, it is difficult to see how this procedure works.
Good luck.
Post A Followup
: Re: Re: H fanbelt needs to be tightened?
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
