Re: H fanbelt needs to be tightened?
Posted by john d on July 13, 2003 at 22:23:24 from (64.12.97.13):
In Reply to: H fanbelt needs to be tightened? posted by John on July 13, 2003 at 19:20:22:
The nut will likely loosen fairly easily. Remove it and the setscrew completely. Attack the built up crud on the hub and the threads with a small wire brush and some cleaner. I replaced the belt on my M last winter, and it had been nearly 40 years since it was moved, also! I had pretty good luck cleaning mine with a can of spray Gum-Out, a small brass-bristle brush about 1/2" wide, and some PB Blaster penetrating oil. Mine had the usual build-up of crud on the threads, and had accumulated a tremendous amount of fine dust into the threads. This dust had effectively locked the hub of the pulley in place so tightly that the setscrew and nut would not have been needed! Use some caution when attacking the hub with a punch to turn it. Don't lose patience, or you will hit it too hard, crack it, and then be in for a much larger adventure. Turn the setscrew hole to the top, flood the inside of the hub with the solvent of your choice, then work the hub back and forth as you are able to. It may need to soak all night before you can move it. Once it starts moving, keep working it both ways until it becomes free enough to turn with your hands. Take a good look at that belt when you start this project. If it's old, hard, cracked, or visibly worn, you may want to cut it off and make the job of loosening the hub easier. If you end up replacing the belt, you probably won't have to do all this for another 30 years or more.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
