674 Diesel (Hydraulic Problem)
Posted by Kevin Manring on July 18, 2003 at 09:33:12 from (67.241.50.8):
My power steering and PTO comes and goes during use.
The PTO will start again if I raise the lift arms up and down.
I use only IH Hy-trans and it's full and clean looking.
Is there a filter some where that could be dirty.
I've had the tractor for some time and have only changed filters on the engine.
Has always worked perfect until this year.
I was told that my Power steering and pto work off the same pump.
thanks for any help you can give me.
Kevin
Post A Followup
: Re: 674 Diesel (Hydraulic Problem)
