Re: Type R carb/40 series diesel engine
Posted by Mr. D on July 21, 2003 at 10:46:09 from (207.91.18.42):
In Reply to: Type R carb/40 series diesel engine posted by brianh on July 21, 2003 at 08:26:53:
the only setting on those carbs is the idle speed as that is the only speed it will run. just set that idle screw so it runs about 700 to 800 rpm on gas. Also there is no air filter or intake pipe on those carbs if that is the air filter you are talking about. There is just a shutter that you close when it switches to diesel to keep the dirt out. When it switches to diesel it draws air through the air filter but just sucks the open air on gas unless you have a later one with the other carb on it.
Post A Followup
: Re: Re: Type R carb/40 series diesel engine
