Electrical problems!
Posted by 49 Cubber! on July 27, 2003 at 15:15:25 from (206.74.216.101):
Ok,had problem with my M not charging.Put on THREE new cutouts and had generator tested at two differnt places and all checks out good with all three cutouts.(Now Im stuck with them until I need them,which at the rate Im going wont be long)Heres the problem:Tractor off,pull out switch gauge goes to about -2 or so.Start up tractor.With light switch on low charge,gauge reads 4 or so at first then drops to 0,resistor is getting hot,but not hot enough to turn red,but enough to burn my finger.Not affected by engine speed.On high charge I get reading anywhere from 5-20 amps depending on engine speed.Turn on the lights and the needle moves back towards 0 then goes back up,again depending on engine speed,to where it was,so thats working ok,right?My concern is the heat from the resistor and the 0 reading on the amp gauge on low charge.Other than that its working fine
Post A Followup
: Re: Electrical problems!
