Re: Re: 1066 Hydro-stat problem
Posted by REDMAN on July 31, 2003 at 10:06:36 from (66.44.173.66):
In Reply to: Re: 1066 Hydro-stat problem posted by Aces on July 31, 2003 at 06:22:58:
you will not have much for brakes and more often than not the steering will not work,it does sound like the rivets in the drive hub let go somewhat but the tractor should still drive and the 3 pt hitch should still work as they run off of a different pump.i would probably check the hyd. filter to see if you have anything in there,metal or anything else.
Post A Followup
: Re: Re: Re: 1066 Hydro-stat problem
