Re: fuel injecters on IH/MD
Posted by Farmaller on August 03, 2003 at 13:19:16 from (152.163.253.102):
In Reply to: fuel injecters on IH/MD posted by super Dave in MN on August 03, 2003 at 12:42:18:
How did this problem occur, was it running before this or has it been sitting awhile?
Post A Followup
: Re: Re: fuel injecters on IH/MD
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
