Re: Gasket material for hydraulics
Posted by TimV on August 19, 2003 at 06:07:39 from (12.39.239.130):
In Reply to: Gasket material for hydraulics posted by David Bean on August 18, 2003 at 09:25:55:
David: Even without knowing the specifics of the application, I'd steer clear of cork. Cork is mainly used for low-pressure applications, and probably will not hold up under even the modest pressures of an older hydraulic system. The "grey paper" is more than likely a lower-grade gasket sheet with a nitrile rubber binder. This should hold up (from a chemical compatibility standpoint) to hydraulic fluid, but may also give problems under elevated pressures due to low tensile strength. However, it's probably the better choice of the two you mentioned. Be wary of using sealant on a hydraulic system--if you put too much on, it can extrude into the sealed cavity, break loose, and clog your system.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
