Re: IH Super M Generator question
Posted by Bob M on August 19, 2003 at 11:14:03 from (165.170.128.66):
In Reply to: IH Super M Generator question posted by Chad on August 19, 2003 at 09:17:30:
Chad - Punch below for a troubleshooting chart that may help diagnose the problem. Other than a loose drive belt or possibly a bad drive end bearing, I can't think of anything you could do that might cause the generator to screech.
A suggestion: If you messed with any of the adjustments inside the regulator get rid of it and install a new one (regulator settings are fussy and hard to get right even when you know what you are doing...) And if the regulator's more than a few years old it probably needs replacing anyway.
Good luck!!
Post A Followup
: Re: Re: IH Super M Generator question
